[geos-devel] Re: [GEOS] #244: Buffer fails to buffer elements of multpolygon
GEOS geos-trac at osgeo.org
Tue May 12 09:19:57 EDT 2009
 Reporter:  pramsey     |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |       Status:  new
 Priority:  major       |    Milestone:  3.1.1
Component:  Default     |      Version:  3.0.3
 Severity:  Unassigned  |   Resolution:
 Keywords:              |
Comment (by strk):
 bug244-simp1.xml is a simplification of the testcases. The input
 multipolygon contains 5 polygons, none with holes. 2 are returned by
 buffer(0).
Ticket URL: <http://trac.osgeo.org/geos/ticket/244#comment:5>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
