[geos-devel] [GEOS] #253: Unexpected "Self-intersection at or near point"
GEOS geos-trac at osgeo.org
Mon May 18 19:17:54 EDT 2009
 Reporter:  wvereeck    |       Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  minor       |   Milestone:  3.1.1
Component:  Core        |     Version:  3.1.0
 Severity:  Unassigned  |    Keywords:  self-intersection
 Hi All,
 I'm very new to GEOS (< 1 day), but I'm puzzled by what I think is a
 strange bug.
 Being particularly interested in the GEOSUnionCascaded() function to merge
 large sets (>50,000) of overlapping polygons, altering my dataset manually
 to avoid this bug(?) is not an option.
 I have narrowed down the problem to the following multipolygon, which
 represents a rectangle inside an octagon (see
 http://homes.esat.kuleuven.be/~wvereeck/rect_inside_oct.png)
 MULTIPOLYGON(((12.26 18.46, 11.76 18.46, 11.54 18.24, 11.54 17.34, 11.76
 17.12, 12.26 17.12, 12.48 17.34, 12.48 18.24, 12.26 18.46)),((12.37 18.35,
 11.65 18.35, 11.65 17.23, 12.37 17.23, 12.37 18.35)))
 I am using the c-interface. Running the GEOSisValid() test on this polygon
 set results in:
    NOTICE: Self-intersection at or near point 12.37 18.35
 Also, GEOSUnionCascaded() accordingly fails with:
    ERROR: TopologyException: found non-noded intersection between 11.65
 etc...
 However, when I slightly offset the x-position (+1e-8) of the two top
 vertices of the rectangle, everything works like a charm (i.e. GEOSisValid
 returns 'true' and GEOSUnionCascaded produces the correct output polygon):
 17.12, 12.26 17.12, 12.48 17.34, 12.48 18.24, 12.26 18.46)), ((12.37000001
 18.35, 11.65000001 18.35, 11.65 17.23, 12.37 17.23, 12.37000001 18.35)))
 I apologize if I'm too much in a hurry here and should start to learn more
 about geos before submitting a complaint :) At least I hope this is the
 right place for this problem.
 Kind Regards,
 Wim Vereecken
 FWIW, I'm using geos-3.1.0.tar.bz2 (2009/03/17), libgeos-3.1.0 and Ubuntu
 8.04.2 (x86-64) with a 2.6.24-23-generic kernel.
Ticket URL: <http://trac.osgeo.org/geos/ticket/253>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
