[geos-devel] 3.1.1
Obe, Regina robe.dnd at cityofboston.gov
Thu May 28 08:00:40 EDT 2009
I don't seem to be able to compile this under OpenSUSE 10.3.  Haven't
tried under my windows box yet.
To get to that point I did a fresh checkout
svn checkout http://svn.osgeo.org/geos/branches/3.1 geos31
cd geos31
sh autogen.sh
make & make install
(Did I miss a step?)
The autogen looks a bit different than I recall -- gives this
sh autogen.sh
* Running /usr/bin/libtoolize (1.5.24)
\tOPTIONS = --force --copy
* Running /usr/bin/aclocal (1.10)
* Running /usr/bin/autoheader (2.61)
* Running /usr/bin/automake (1.10)
\tOPTIONS = --add-missing --copy
* Running /usr/bin/autoconf (2.61)
then make
everything before this point looks okay and then
I get this error
mv -f .deps/SimplePointInAreaLocator.Tpo
/bin/sh ../../../libtool --tag=CXX   --mode=link g++  -g -O2
-DGEOS_INLINE  -pedantic -Wall -ansi -Wno-long-long   -o liblocation.la
IndexedPointInAreaLocator.lo PointOnGeometryLocator.lo
libtool: link: `IndexedPointInAreaLocator.lo' is not a valid libtool
make[4]: *** [liblocation.la] Error 1
make[4]: Leaving directory `/projects/geos31/source/algorithm/locate'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/projects/geos31/source/algorithm/locate'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/projects/geos31/source/algorithm'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/projects/geos31/source'
make: *** [all-recursive] Error 1
-----Original Message-----
[mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Wednesday, May 27, 2009 2:32 PM
To: GEOS Development List
Subject: [geos-devel] 3.1.1
I'd like to cut a 3.1.1, including Frank's GEOSFree in the CAPI and a
handful of minor fixes I was able to cull from Sandro's comprehensive
work on trunk.
Can I have a bit of cursory testing on the current SVN 3.1 branch?
Paul Ramsey
OpenGeo - http://opengeo.org
The PostGIS with the MostGIS.
geos-devel mailing list
geos-devel at lists.osgeo.org
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
