[geos-devel] Benchmark between various geometry libraries
Paul Ramsey pramsey at cleverelephant.ca
Wed Nov 18 12:18:58 EST 2009
I see that Matz has already been looking at a GGL binding for PostGIS,
and I think when the 2.0 cycle begins I will also examine the
possibility. Then we can see where the rubber meets the road. Even
where GGL has a strong base-case speed, thinks like PreparedGeometry
will probably make GEOS faster for common predicate use cases (not
that GGL can't steal that idea too, eventually).
P.
On Wed, Nov 18, 2009 at 8:55 AM, Martin Davis <mbdavis at refractions.net> wrote:
> I'm not sure that anything "went wrong" with the tests.  The results may be
> due to fundamental design differences between GGL and GEOS.  These include:
> - GEOS uses a less efficient memory handling strategy, primarily due to the
> goal of tracking JTS closely (and also due to the substantial brainpower
> required to grok C++ template programming)
> - GEOS focuses heavily on providing robustness and ability to handle a wide
> variety of real-world geometry correctly.  This requires using some
> algorithms and extra checking which have an impact on performance
> The robustness question I think is a key one.  In order for a library to be
> viable in an uncontrolled production setting such as PostGIS, it needs to be
> highly robust.  I think this needs to be considered of equal importance to
> performance for these kinds of uses.
> Maxime van Noppen wrote:
>> Hi list,
>> A geometry library is currently being reviewed by the Boost project (GGL
>> - Generic Geometry Library)[1] and they did some benchmarks available
>> here:
>> http://trac.osgeo.org/ggl/wiki/IntersectionMore
>> http://trac.osgeo.org/ggl/wiki/IntersectionStarComb
>> Depending on the situations geos performs well or quite bad.
>> It could be interesting to investigate what went wrong with those tests.
>> [1] http://lists.boost.org/boost-users/2009/11/53451.php
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
