[geos-devel] Re: [GEOS] #287: Shouldn't GEOS 3.1 branch be bumped to 3.1.2
GEOS geos-trac at osgeo.org
Wed Nov 18 13:59:23 EST 2009
 Reporter:  robe        |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |       Status:  closed
 Priority:  trivial     |    Milestone:  3.1.2
Component:  Default     |      Version:  3.1.1
 Severity:  Unassigned  |   Resolution:  fixed
 Keywords:              |
Comment (by pramsey):
 Reversed the upgrade process a bit, bump up revision numbers *after*
 release so that the repo version is always one higher than the release
 version.
Ticket URL: <http://trac.osgeo.org/geos/ticket/287#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
