[geos-devel] platform.h and config.h
strk strk at keybit.net
Thu Nov 26 16:44:23 EST 2009
I've added ISNAN detection result in platform.h instead.
config.h seems to be unused except from a profiler.h file
which probably doesn't need it in turn..
I'd drop config.h (after release though).
Please test r2748. (./configure sould do, no need to autogen.sh again)
--strk;
On Thu, Nov 26, 2009 at 12:40:29PM -0800, Paul Ramsey wrote:
> I'm tracking down a build failure in Solaris, which is happening because the code is trying to use an std::isnan() that is not there. It is odd, because ./configure is correctly detecting the presence of a cmath isnan(), but the code isn't using it.
> What I am seeing is that platform.h has the proper switches in place to handle the problem, but nowhere is config.h, which contains the results of the configure run included, so the switches never actually move.
> Can someone confirm my diagnosis and solution (add config.h into platform.h at the top) before I make this core change to the build?
> Paul_______________________________________________
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
 Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
 http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
