[geos-devel] RE: {SPAM: 40} :Re: autogen.bat
Sanak Goe geosanak at gmail.com
Sat Nov 28 05:35:39 EST 2009
Hi Regina,
I think that the problem is platform.h and version.h are packaged in rc tar
ball.
If these files doesn't exist in "source/headers/geos" folder, VS 2008 build
process will copy from *.h.vc, and build successfully.
But, I don't now detail of VS 2008 custom build step behavior(property of *.
h.vc).
Regards,
Sanak.
2009/11/20 Obe, Regina <robe.dnd at cityofboston.gov>
> Those only work for Linux boxes I think.  So I had to download the
> autoexec.bat and run that against my tar download to get it to compile under
> VS 2008 C++ Express.  I'll have to try with the solution files on my other
> box as I don't recall ever having to do this before.  Then again in prior
> versions the tar ball was broken so wouldn't compile under VS anyway so I
> always had to use subversion version.
> The frustrations of being a citizen of the evil empire :)
> Thanks,
> Regina
> ________________________________________
> From: strk [strk at keybit.net]
> Sent: Thursday, November 19, 2009 4:41 PM
> To: Mateusz Loskot; Obe, Regina
> Cc: GEOS Development List
> Subject: {SPAM: 40} :Re: autogen.bat
> On Tue, Nov 17, 2009 at 11:16:28PM +0000, Mateusz Loskot wrote:
> > I assumed that GEOS distribution is supposed to already
> > provide generated and valid version.h and platform.h and geos_c.h
> Uhm, those are distributed indeed.
> Regina, do you still need autogen.bat to complete a build out-of-the-box ?
> --strk;
>  Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
>  http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20091128/87ad0952/attachment.html
