[geos-devel] Find self-intersections
strk strk at keybit.net
Sat Nov 28 13:22:48 EST 2009
What do you really need to do at the end of the day ?
Want a simple ring ? A polygon ?
--strk;
On Fri, Nov 27, 2009 at 05:22:22PM +0100, Frederik Ramm wrote:
> Hi,
>    today I came across the following problem that I tried to solve with
> GEOS.
> I had 3.000 linestrings which together formed one large ring. However,
> this ring was not simple; it was 8-shaped. I wanted to find out where
> the intersection point - or perhaps the intersection line! - was.
> The best I could come up with was:
> for (i=0; i<count; i++)
>    for (j=i+1; j<count; j++)
>       Geometry *p = linestring[i]->intersection(linestring[j])
>       if (p)
>          // found something
> This is of course rather inefficient! I'd better build a LinearRing from
> the lot of them and then query for self-intersection. I did find some
> code that does this when looking at how isSimple() is implemented;
> however, that code would only find self intersection points, not lines.
> I wonder if there is some generic way to determine a geometry's "self
> intersection"?
> Bye
> Frederik
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
 Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
 http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
