[geos-devel] Re: [GEOS] #375: Intersection between two valid geometries yelds an invalid one
GEOS geos-trac at osgeo.org
Fri Aug 27 04:42:19 EDT 2010
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.0.3
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 Interesting enough, the following tests also fail with invalid return from
 Intersection:
 tests/stmlf/stmlf-cases-20061020.xml: case1: test1
 tests/stmlf/stmlf-cases-20061020.xml: case20: test1
 tests/stmlf/stmlf-cases-20061020.xml: case24: test1
 tests/stmlf/stmlf-cases-20061020.xml: case25: test1
Ticket URL: <http://trac.osgeo.org/geos/ticket/375#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
