[geos-devel] [GEOS] #389: BufferOp assertion on make check
GEOS geos-trac at osgeo.org
Tue Dec 7 07:05:11 EST 2010
 Reporter:  alopezcia   |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:
 Severity:  Unassigned  |    Keywords:
 Hello,
 any suggestion to determinate the error causes?
 geos::simplify::TopologyPreservingSimplifier: ..........
 geos::util::UniqueCoordinateArrayFilter: .
 ---> group: geos::operation::buffer::BufferOp, test: test<4>
 problem: assertion failed
 tests summary: failures:1 ok:556
 FAIL: geos_unit
 1 of 1 test failed
 make: 1254-004 The error code from the last command is 1.
 I'm using AIX 5.3, gcc 4.2.4 with this options
 CC=gcc
 CFLAGS='-maix64 -DSYSV -D_AIX -D_AIX32 -D_AIX41 -D_AIX43 -D_AIX51 -D_AIX53
 -D_AIX53 -D_ALL_SOURCE -DFUNCPROTO=15 -O -I/opt/freeware/include'
 CXX=g++
 CXXFLAGS='-maix64 -DSYSV -D_AIX -D_AIX32 -D_AIX41 -D_AIX43 -D_AIX51
 -D_AIX53 -D_
 LD=ld
 LDFLAGS=-L/opt/freeware/lib/gcc/powerpc-ibm-aix5.3.0.0/4.2.4/ppc64
Ticket URL: <http://trac.osgeo.org/geos/ticket/389>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
