[geos-devel] [GEOS] #316: Python library check is not 64 bits free
GEOS geos-trac at osgeo.org
Tue Jan 12 15:25:14 EST 2010
 Reporter:  bicatali    |       Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.2.0
 Severity:  Unassigned  |    Keywords:
 When the system is 64bits only (on *nix systems), the Python library check
 does not work:
 checking for python... /usr/bin/python
 checking for python version... 2.6
 checking for python platform... linux2
 checking for python script directory... ${prefix}/lib/python2.6/site-
 checking for python extension module directory...
 checking for Python include path... /usr/include/python2.6
 checking for Python library path...
 configure: error: cannot find Python library path
 In macros/ac_python_devel.m4, changing lib/python with $libdir/python
 should resolve it.
Ticket URL: <http://trac.osgeo.org/geos/ticket/316>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
