[geos-devel] Re: [GEOS] #321: crash in geos::geom::WKTWriter
GEOS geos-trac at osgeo.org
Fri Jan 22 07:42:53 EST 2010
 Reporter:  12345678    |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |       Status:  closed
 Priority:  major       |    Milestone:
Component:  Default     |      Version:  3.2.0
 Severity:  Unassigned  |   Resolution:  invalid
 Keywords:              |
Changes (by mloskot):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 No clue, unless you stick to
 http://www.chiark.greenend.org.uk/~sgtatham/bugs.html principles of bug
 reporting] and provide us with minimum information required to investigate
 your problem.
 Otherwise, the report is invalid.
Ticket URL: <http://trac.osgeo.org/geos/ticket/321#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
