[geos-devel] Build and install instructions
Mateusz Loskot mateusz at loskot.net
Thu Jan 28 13:42:00 EST 2010
strk wrote:
> On Wed, Jan 27, 2010 at 11:52:47PM +0000, Mateusz Loskot wrote:
>> I reorganised the Build and Install instructions a bit:
>> http://trac.osgeo.org/geos/wiki#BuildandInstall
>> Please, update if anything is missing or buggy.
> May I ask for 'make check' rather than 'make test' for the Test
> TODO item ? 'check' is a GNU standard rule.
Sandro,
GNU != OSGeo ;-)
Seriously, no problem. "make test" is standard target
name of CTest run by CMake, and I'd like to not to disable it,
But there is no problem to provide both. OK?
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
