[geos-devel] Re: [GEOS] #323: A point interpolated from a line does
 not always intersect the same line
    geos-trac at osgeo.org
    Sun Jan 31 00:23:31 EST 2010
#323: A point interpolated from a line does not always intersect the same line
 Reporter:  starsareblue  |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect        |       Status:  reopened
 Priority:  major         |    Milestone:
Component:  Default       |      Version:  3.2.0
 Severity:  Unassigned    |   Resolution:
 Keywords:                |
Comment (by starsareblue):
 The interpolate and project methods correspond to the linear referencing
 methods in the GEOS 3.2 API.  You can see similar strange behavior in the
 GeoDjango package ( http://code.djangoproject.com/attachment/ticket/11948/
 contrib-gis-linearref.patch ) so I assumed the problem had to do with GEOS
 itself.
 Here is another example.  The first interpolation is correct.  However,
 the second interpolation is wrong.  It looks like some kind of wraparound
 is happening incompletely for the edge case when the interpolation result
 for a MultiLineString happens on the endpoint of one of its LineStrings.
 In [1]: import shapely.geometry as g
 In [2]: m = g.MultiLineString([[(0, -2), (0, 2)], [(-2, 0), (2, 0)]])
 In [3]: m.interpolate(m.project(g.Point(2,1.9))).wkt    # Correct
 Out[3]: 'POINT (2.0000000000000000 0.0000000000000000)'
 In [4]: m.interpolate(m.project(g.Point(2,2.1))).wkt    # Wrong
 Out[4]: 'POINT (-2.0000000000000000 0.0000000000000000)'
 Roy Hyunjin Han
 http://invisibleroads.com
 Empowering people to create since 2008
Ticket URL: <http://trac.osgeo.org/geos/ticket/323#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
