[geos-devel] [GEOS] #356: Buffer error
GEOS geos-trac at osgeo.org
Thu Jun 24 11:32:29 EDT 2010
#356: Buffer error
 Reporter:  aperi2007   |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.2.1
Component:  Default     |     Version:  3.2.0
 Severity:  Unassigned  |    Keywords:
 In postgis try-ing a Buffer with this:
 select
     1 as id,
         ST_Buffer(ST_GeomFromText('MULTILINESTRING(
         (1676339.95971128 4847443.67952346,
         1676340.19 4847443.54,
         1676338.44 4847440.65,
         1676335.37 4847442.52,
         1676337.12 4847445.4,
         1676339.95971128 4847443.67952346)
 )'),1) as geom;
 I experience a Bug .
 The buffer build a Polygon with a strange secondary polygon near a vertex.
 The Geos used from Postgis 1.5.1 is Geos 3.2.0, so I try
 downloading the last Geos 3.2.2 compile and use it.
 But the bug is still here.
 I work with windows , postgis 1.5.1.
Ticket URL: <http://trac.osgeo.org/geos/ticket/356>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
