[geos-devel] use of STRtree functions in C API
Roger Bivand Roger.Bivand at nhh.no
Thu May 6 12:33:40 EDT 2010
On Tue, 4 May 2010, Gavin Heavyside wrote:
> On 4 May 2010 14:30, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>> Hi,
>> I'm investigating the use of STRtree functions in C API to find candidate
>> GEOS_MULTIPOLYGON or GEOS_POLYGON objects to test for contiguity, with
>> GEOSDisjoint() or GEOSTouches(). I think that I can see how to build the
>> tree with envelopes of the polygon objects, using an int ID number as the
>> inserted item. However, I'm very unsure how:
>> extern void GEOS_DLL GEOSSTRtree_query_r(GEOSContextHandle_t handle,
>>                                         GEOSSTRtree *tree,
>>                                         const GEOSGeometry *g,
>>                                         GEOSQueryCallback callback,
>>                                         void *userdata);
>> should be understood. The first three arguments appear clear, but neither of
>> the remaining two is. userdata out could be a structure with a pre-allocated
>> int array long enough to hold any intersected object IDs, with an int saying
>> how many are present. Does anyone have any use examples of GEOSSTRtree_query
>> in the C API?
>> Grateful for any pointers,
> I don't have any example code handy, but I did get a test program
> working with the RTree API a little while ago.
> If I remember correctly, you define your own GEOSQueryCallback
> function and pass the address in when you make the query. Your
> callback is then called once for each geometry in the RTree that
> bounding-box-overlaps the geometry passed to the query.
> The userdata pointer allows you to provide a pointer to whatever data
> you might need.  Your callback receives the matching geometry from the
> rtree and your userdata each time it is called, you can cast it back
> to the appropriate type in the callback.  e.g. You might want to pass
> a pointer that gives you access to the geometry used in the query, so
> you can do more specific comparisons between the geometries.
> Hope this helps a little,
Yes, thanks, Gavin. I had looked at the callback and thought it looked
forbidding, but the results are good - despite compiler warnings both
building the tree and querying it. We can now find census blocks that
neighbour one another in Los Angeles (almost 90K polygons) in under 10
seconds, compared to over 10 minutes without spatial indexing. I'm only
retrieving the input envelope ID values, not the geometries, which for our
purposes are not needed.
Roger
> Gavin
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
