[geos-devel] [GEOS] #343: After applying a buffer over a multiline the library starts growing in memory usage and hungs
GEOS geos-trac at osgeo.org
Thu May 13 11:11:39 EDT 2010
 Reporter:  sberna      |       Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.2.0
 Severity:  Unassigned  |    Keywords:
 After applying a buffer of 0.005 to the attached geometry in hex wkb the
 library starts growing in memory usage until the kernel kills it. It never
 returns the buffered geometry nor any error message.
Ticket URL: <http://trac.osgeo.org/geos/ticket/343>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
