[geos-devel] [GEOS] #343: After applying a buffer over a multiline the library starts growing in memory usage and hungs
Martin Davis mbdavis at refractions.net
Thu May 13 11:54:57 EDT 2010
Yikes!  That's one nasty dataset.  JTS has issues with it as well - I
wasn't able to get the buffer to complete.
As a workaround, you could buffer each line separately and then
UnaryUnion the results.
>  Reporter:  sberna      |       Owner:  geos-devel at lists.osgeo.org
>      Type:  defect      |      Status:  new
>  Priority:  major       |   Milestone:
> Component:  Default     |     Version:  3.2.0
>  Severity:  Unassigned  |    Keywords:
>  After applying a buffer of 0.005 to the attached geometry in hex wkb the
>  library starts growing in memory usage until the kernel kills it. It never
>  returns the buffered geometry nor any error message.
> geos-devel mailing list
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
