[geos-devel] Re: [GEOS] #344: After applying a buffer over a multiline the library starts growing in memory usage and hungs
GEOS geos-trac at osgeo.org
Fri May 14 05:11:14 EDT 2010
 Reporter:  sberna      |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |       Status:  new
 Priority:  major       |    Milestone:
Component:  Default     |      Version:  3.2.0
 Severity:  Unassigned  |   Resolution:
 Keywords:              |
Comment (by strk):
 Replying to [comment:1 sberna]:
 > Both geometries are reported as valid by the library.
 Note that GEOS-3.2.1 contains a fix for a bug giving false positives for
 ValidOp.
Ticket URL: <http://trac.osgeo.org/geos/ticket/344#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
