[geos-devel] [GEOS] #343: After applying a buffer over a multiline the library starts growing in memory usage and hungs
Martin Davis mbdavis at refractions.net
Fri May 14 14:28:48 EDT 2010
Ah, ok.  I was using this one.
http://trac.osgeo.org/geos/attachment/ticket/344/fail_geom.txt.gz
I'll try the other one and see what kind of performance I get.
strk wrote:
> On Fri, May 14, 2010 at 09:11:30AM -0700, Martin Davis wrote:
>> I'm surprise that PostGIS is so much faster too!  Can you supply the
>> output, so I can check it against JTS?
>> One thing I notice is that the input I'm using has 5615 elements and
>> 11502 points.
> The input I'm using is this:
> http://trac.osgeo.org/geos/attachment/ticket/344/roads_broken_geom.txt.gz
> The output I have with it is attached.
> --strk;
>   ()   Free GIS & Flash consultant/developer
>   /\   http://strk.keybit.net/services.html
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
