[geos-devel] Dimension and Coordinate Sequences
strk strk at keybit.net
Mon May 17 12:12:53 EDT 2010
On Mon, May 17, 2010 at 11:42:34AM -0400, Frank Warmerdam wrote:
> Is this a good time for me to take a crack at implementing dimension
> support?   I see the dimension potentially makes it as far as the
> CoordinateArraySequenceFactory, but that CoordinateArraySequence has
> nothing to keep track of it.  I could add it as a private member and
> ensure it is passed in by the factory.
Sure, you may try that.
Only, I highly dubt any computation will check dimension of input(s)
and use that to dimension the output.
I belive neither JTS will do that, is that correct Martin ?
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
