[geos-devel] getCoordinateDimension() - ticket 311
Martin Davis mbdavis at refractions.net
Wed May 26 12:08:24 EDT 2010
getDimension follows the OGC spec.  Seems to me it's better to simply
change it to match the spec and the C++ API.  This was clearly a bug in
the first place, no?
strk wrote:
> On Tue, May 25, 2010 at 09:27:16PM -0400, Frank Warmerdam wrote:
>> I think we will have to change the values returned by the C API getDimension
>> function to match C++ even though this introduces a modest risk of problems
>> for applications using the undocumented current behavior.
> What's the problem with deprecating it and use a new, more explicit name ?
>  GEOSGeom_getSpatialDimension() maybe ?
> Note that there are other functions which I think should be deprecated
> so getDimension won't feel alone (the setOrdinate/getOrdinate ones
> in particular, as they use 1-based index and in an undocumented way).
> --strk;
>   ()   Free GIS & Flash consultant/developer
>   /\   http://strk.keybit.net/services.html
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
