[geos-devel] Re: [GEOS] #469: testrunner fail
GEOS geos-trac at osgeo.org
Mon Aug 22 13:44:56 EDT 2011
 Reporter:  aperi2007   |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.1
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 Can you obtain a backtrace ?
 If you edit 'testrunner' (it's a shell script) you can add a 'gdb --args'
 prefix to the ./XMLTester call, the enter 'bt'<enter> when you get the
 assertion
Ticket URL: <http://trac.osgeo.org/geos/ticket/469#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
