[geos-devel] Re: [GEOS] #469: testrunner fail
GEOS geos-trac at osgeo.org
Mon Aug 22 14:56:01 EDT 2011
 Reporter:  aperi2007   |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.1
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 Oops, XMLTester is a libtool script, you'll need:
 libtool --mode=execute gdb --args ./XMLTester ....
Ticket URL: <http://trac.osgeo.org/geos/ticket/469#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
