[geos-devel] Re: [GEOS] #469: testrunner fail
GEOS geos-trac at osgeo.org
Mon Aug 22 17:53:57 EDT 2011
 Reporter:  aperi2007   |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.1
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
Comment(by aperi2007):
 changing the configure phase in this mode it seem work.
 CFLAGS="-m64" CPPFLAGS="-m64" CXXFLAGS="-m64" LDFLAGS="-m64" FFLAGS="-m64"
 LDFLAGS="-L/usr/lib64/" ./configure --enable-python
 Now the "make check" start and end without any error.
 it only report some strange notice like these:
 capi::GEOSBuffer: ....................
 capi::GEOSContains: ...
 capi::GEOSCoordSeq: ......
 capi::GEOSDistance: .
 capi::GEOSGeomFromWKB: .....
 capi::GEOSGeomToWKT: .............
 capi::GEOSGeom_create: .......
 capi::GEOSGeom_extractUniquePoints: ...
 capi::GEOSIntersects: ...NOTICE: IllegalArgumentException:
 RobustDeterminant encountered non-finite numbers
 .NOTICE: IllegalArgumentException: RobustDeterminant encountered non-
 finite numbers
 capi::GEOSLineStringPoint: ...
 capi::GEOSOffsetCurve: ......
 capi::GEOSOrientationIndex: ...........
 capi::GEOSPolygonizeGetCutEdges: ..
 capi::GEOSPreparedGeometry: ......
 capi::GEOSRelateBoundaryNodeRule: .......NOTICE: Invalid boundary node
 rule 5
 capi::GEOSRelatePatternMatch: .....NOTICE: IllegalArgumentException:
 Geometry is not lineal
 capi::GEOSSharedPaths: ..NOTICE: IllegalArgumentException: Geometry is not
 lineal
 capi::GEOSSimplify: .
 capi::GEOSSnap: ....
 capi::GEOSUnaryUnion: ........
 capi::GEOSWithin: ...
 capi::GEOSisValidDetail: ......
 geos::algorithm::Angle: ....
 geos::algorithm::CGAlgorithms::computeOrientation: ..
 geos::algorithm::CGAlgorithms::isCCW: .....
 geos::algorithm::CGAlgorithms::isPointInRing: ..
 geos::algorithm::CGAlgorithms::signedArea: ...
 geos::algorithm::ConvexHull: .......
 geos::algorithm::PointLocator: ....
 geos::algorithm::RobustLineIntersection: ..
 geos::algorithm::RobustLineIntersector: .............
 geos::algorithm::distace::DiscreteHausdorffDistance: ....
 geos::geom::Coordinate: .........
 geos::geom::CoordinateArraySequence: .................
 geos::geom::CoordinateArraySequenceFactory: ....
 geos::geom::CoordinateList: ..
 geos::geom::Dimension: .....
 geos::geom::Envelope: .........
 geos::geom::Geometry::clone: .......
 geos::geom::Geometry::covers: ...
 geos::geom::Geometry::isRectangle: .......
 geos::geom::GeometryFactory: ....................................
 geos::geom::IntersectionMatrix: .............................
 geos::geom::LineSegment: ......
 geos::geom::LineString: .........................
 geos::geom::LinearRing: ..............................
 geos::geom::Location: ...
 geos::geom::MultiLineString: .
 geos::geom::MultiPoint: ............................
 geos::geom::MultiPolygon: .
 geos::geom::Point: ........................................
 geos::geom::Polygon: .....................................
 geos::geom::PrecisionModel: .........
 geos::geom::Triangle: .....
 geos::geom::prep::PreparedGeometryFactory: .............................
 geos::geom::util::GeometryExtracter: ..
 geos::index::quadtree::DoubleBits: .
 geos::io::ByteOrderValues: ...
 geos::io::WKBReader: .......
 geos::io::WKBWriter: ...
 geos::io::WKTReader: ......
 geos::io::WKTWriter: .....
 geos::linearref::LocationIndexedLine: ........................
 geos::noding::BasicSegmentString: ....
 geos::noding::NodedSegmentString: .....
 geos::noding::SegmentNode: ....
 geos::noding::SegmentPointComparator: .....
 geos::operation::IsSimpleOp: ...
 geos::operation::buffer::BufferOp: .........
 geos::operation::distance::DistanceOp: ...................
 geos::operation::geounion::CascadedPolygonUnion: .
 geos::operation::geounion::UnaryUnionOp: .....
 geos::operation::linemerge::LineMerger: ......
 geos::operation::linemerge::LineSequencer: ............
 geos::operation::overlay::snap::GeometrySnapper: ..
 geos::operation::overlay::snap::LineStringSnapper: .......
 geos::operation::overlay::validate::FuzzyPointLocator: .......
 geos::operation::overlay::validate::OffsetPointGenerator: .....
 geos::operation::overlay::validate::OverlayResultValidator: ......
 geos::operation::polygonize::Polygonizer: ..
 geos::operation::sharedpaths::SharedPathsOp: .....................
 geos::operation::valid::IsValidOp: .
 geos::operation::valid::ValidClosedRing: .....
 geos::operation::valid::ValidSelfTouchingRingFormingHole: .......
 geos::precision::SimpleGeometryPrecisionReducer: .......
 geos::simplify::DouglasPeuckerSimplifier: ..........
 geos::simplify::TopologyPreservingSimplifier: ..........
 geos::util::UniqueCoordinateArrayFilter: .
 tests summary: ok:732
 PASS: geos_unit
 1 test passed
 I don't know if these are serious errors .
Ticket URL: <http://trac.osgeo.org/geos/ticket/469#comment:8>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
