[geos-devel] Re: [GEOS] #494: Rectangular buffer with little resemblance of input
GEOS geos-trac at osgeo.org
Fri Dec 9 05:12:42 EST 2011
 Reporter:  strk        |        Owner:  geos-devel@…
     Type:  defect      |       Status:  closed
 Priority:  major       |    Milestone:  3.3.2
Component:  Default     |      Version:  3.3.1
 Severity:  Unassigned  |   Resolution:  fixed
 Keywords:              |
Comment(by strk):
 See also http://trac.osgeo.org/geos/wiki/BufferRobustness
 And commits r3535 (for trunk) and r3537 (3.3 branch).
 The testcase was embedded in
 tests/xmltester/tests/safe/TestBufferJagged.xml
Ticket URL: <http://trac.osgeo.org/geos/ticket/494#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
