[geos-devel] Re: [GEOS] #488: TopologyException unioning valid geometries
GEOS geos-trac at osgeo.org
Mon Dec 12 04:41:34 EST 2011
 Reporter:  sky         |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.2
Component:  Default     |     Version:  3.3.1
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 sky: could you turn your input data into an XML test ?
 See source:trunk/tests/xmltester/tests/ticket/bug275.xml for an example
Ticket URL: <http://trac.osgeo.org/geos/ticket/488#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
