[geos-devel] Re: [GEOS] #500: default initialization of an object of const type 'const geos::operation::overlay::OverlayNodeFactory' requires a user-provided default constructor
GEOS geos-trac at osgeo.org
Mon Dec 12 04:46:48 EST 2011
default       constructor
 Reporter:  hobu        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  minor       |   Milestone:  3.3.2
Component:  Default     |     Version:  3.3.1
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 OverlayNodeFactory does have a user-provided default constructor.
 Only it is inlined (it's in OverlayNodeFactory.h).
 Anyway, does moving the static into the ::instance() method fixes the
 build with clang ?
 See attached patch.
Ticket URL: <http://trac.osgeo.org/geos/ticket/500#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
