[geos-devel] Re: [GEOS] #488: TopologyException unioning valid geometries
GEOS geos-trac at osgeo.org
Wed Dec 14 11:45:23 EST 2011
 Reporter:  sky         |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.2
Component:  Default     |     Version:  3.3.1
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 Put POLYGON EMPTY for now, first bug to spot/fix would be the
 TopologyException. I'll use the XML test to try JTS against it, and
 different versions of GEOS. When (and if) I get a valid result I can
 update the expected part.
Ticket URL: <http://trac.osgeo.org/geos/ticket/488#comment:8>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
