[geos-devel] Re: [GEOS] #488: TopologyException unioning valid geometries [JTS fails]
GEOS geos-trac at osgeo.org
Wed Dec 14 15:34:08 EST 2011
 Reporter:  sky         |        Owner:  geos-devel@…
     Type:  defect      |       Status:  reopened
 Priority:  major       |    Milestone:  3.4.0
Component:  Default     |      Version:  svn-trunk
 Severity:  Unassigned  |   Resolution:
 Keywords:  jts fails   |
Comment(by strk):
 I've replaced the XML test to use GEOMETRYCOLLECTION ratehr than
 MULTIPOLYGON. That way the validity checker checks for validity of each
 and every component, and succeeds (the validity checking).
 Next step would be filing the bug upstream in JTS
Ticket URL: <http://trac.osgeo.org/geos/ticket/488#comment:20>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
