[geos-devel] Re: [GEOS] #488: TopologyException unioning valid geometries [JTS fails]
GEOS geos-trac at osgeo.org
Wed Dec 14 20:04:59 EST 2011
 Reporter:  sky         |        Owner:  geos-devel@…
     Type:  defect      |       Status:  reopened
 Priority:  major       |    Milestone:  GEOS Future
Component:  Default     |      Version:  svn-trunk
 Severity:  Unassigned  |   Resolution:
 Keywords:  jts fails   |
Comment(by mdavis):
 This issue is caused by the fact that the input geometry has vertices with
 very high precision, and nearly-coincident line segments.  This occurs
 both internal to and between geometries.
 Attached is a reduced test case containing only two polygons and using
 binary union directly.
 This is a common cause of robustness failure in the current JTS/GEOS
 overlay algorithm.  Fixing this will require some deep design changes in
 JTS and/or better heuristics for handling failures.
 A workaround is to reduce the precision of the input geometries.  Using 10
 decimal places seems to work.
Ticket URL: <http://trac.osgeo.org/geos/ticket/488#comment:24>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
