[geos-devel] RE: [Jts-topo-suite-user] JTS Topology error
strk strk at keybit.net
Thu Feb 3 03:14:14 EST 2011
On Thu, Feb 03, 2011 at 10:25:08AM +1030, James.Sewell at lisasoft.com wrote:
> (Crossposting to GEOS list)
> I see. So the difference between the GeometryNoder with a PrecisionModel and using ST_Snaptogrid from PostGIS on the input geometries is that the GeometryNoder snaps all nodes which are created by the noding process as it works?
> This seems like an elegant solution to deal with the roundoff issues.
> I gather GEOS doesn't expose noding functionality in this way? Is this something that could possibly be added? From PostGIS would a command like ST_Node(geometry, 10E-10) make sense / be plausible? Or would a better solution be to define the precision for each geometry column?
Check the new ST_Snap() function in PostGIS and GEOS svn repository.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
