[geos-devel] Nightly build performance
Sandro Santilli strk at keybit.net
Fri Feb 18 02:23:19 EST 2011
On Fri, Feb 18, 2011 at 01:52:47PM +1030, James.Sewell at lisasoft.com wrote:
> The issue I have noticed is that the newer version is noticeably (more than 5x) slower on some large queries of the form:
> 	SELECT a.geom FROM left AS a, right AS b
> 		WHERE st_intersects(a.the_geom, b.the_geom);
> Have there been changes in this area of the code? Is this expected for nightly builds? Is there anything I can do to help troubleshooting of the issue? All my tables are imported and indexed by the same tool in both instances.
If you can, compare again, using _st_intersects (skips the index).
And keep track of GEOS svn id of the source if they are different.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
