[geos-devel] Re: [GEOS] #389: BufferOp assertion on make check
GEOS geos-trac at osgeo.org
Wed Feb 23 06:14:51 EST 2011
 Reporter:  alopezcia   |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 That testcase isn't very useful in that it doesn't say much.
 Anyway a comment says that the tests are also available as buffer.xml in
 the xmltester test suite.
 Do you get failures in there too ? (make check under tests/xmltester)
Ticket URL: <http://trac.osgeo.org/geos/ticket/389#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
