[geos-devel] Re: [GEOS] #368: TopologyException on Union of valid geometries.
Martin Davis mtnclimb at telus.net
Thu Feb 24 00:01:08 EST 2011
I took a quick look at this. It's a pretty typical robustness problem,
which I guess the various heuristics currently in JTS don't handle well
enough. Some more work on the snapping code might help to solve this.
Failing that, a new approach is required.
Martin
>   Reporter:  yabo        |       Owner:  geos-devel@…
>       Type:  defect      |      Status:  new
>   Priority:  major       |   Milestone:
> Component:  Default     |     Version:  svn-trunk
>   Severity:  Unassigned  |    Keywords:
> Comment(by strk):
>   Also fails with JTS:
>   https://sourceforge.net/tracker/?func=detail&aid=3190026&group_id=128875&atid=713120
