[geos-devel] Re: [GEOS] #356: multilinestring buffer artifacts
GEOS geos-trac at osgeo.org
Fri Feb 25 05:16:44 EST 2011
 Reporter:  aperi2007   |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.0
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 JTS trunk works fine with this one, giving:
 POLYGON ((1676334.370908338 4847442.47738721, 1676334.381771572
 4847442.672985536, 1676334.430559768 4847442.86271278, 1676334.515400594
 4847443.039287834, 1676336.265400594 4847445.919287834, 1676336.383019845
 4847446.075914382, 1676336.528914198 4847446.206608688, 1676336.697486246
 4847446.306356514, 1676336.882268526 4847446.371330916, 1676337.07617165
 4847446.399039078, 1676337.2717563 4847446.388417942, 1676337.461518643
 4847446.339875002, 1676337.638178226 4847446.255272662, 1676340.477889498
 4847444.534796128, 1676340.477889507 4847444.534796122, 1676340.708178227
 4847444.395272662, 1676340.865054944 4847444.277767458, 1676340.995997551
 4847444.13191887, 1676341.095975523 4847443.963330074, 1676341.16114793
 4847443.778477878, 1676341.189010992 4847443.584463894, 1676341.178494273
 4847443.388741704, 1676341.130001801 4847443.19883052, 1676341.04539655
 4847443.022026312, 1676339.29539655 4847440.132026312, 1676339.177687757
 4847439.974857962, 1676339.031535752 4847439.843721232, 1676338.862575756
 4847439.743672394, 1676338.6773224 4847439.678569058, 1676338.482918545
 4847439.650921426, 1676338.286859869 4847439.661795518, 1676338.096705855
 4847439.710772058, 1676337.91978832 4847439.795962644, 1676334.84978832
 4847441.665962642, 1676334.693269131 4847441.783769514, 1676334.56272065
 4847441.92983049, 1676334.463152898 4847442.098540236, 1676334.398386959
 4847442.283424222, 1676334.370908338 4847442.47738721),
 (1676338.816753609 4847443.202781668, 1676337.455985112 4847444.027221212,
 1676336.743325995 4847442.854387922, 1676338.10393518 4847442.025612946,
 1676338.816753609 4847443.202781668))
Ticket URL: <http://trac.osgeo.org/geos/ticket/356#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
