[geos-devel] Re: [GEOS] #356: multilinestring buffer artifacts
GEOS geos-trac at osgeo.org
Fri Feb 25 10:45:09 EST 2011
 Reporter:  aperi2007   |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.0
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 Interesting enough, like GEOS also JTS fails buffering this input with the
 original precision.
 Odd, as the input is a very simple rectangle with a side of 3.5 units (a
 linestring) being buffered with a distance of 1 unit.
 Full coordinates are in the order of 1E6 units.
 The exception thrown (by both GEOS and JTS) when attempting the operation
 on the orginal input is:
 TopologyException: assigned depths do not match [ (1676339.4415330526,
 4847442.824250799, NaN) ]
Ticket URL: <http://trac.osgeo.org/geos/ticket/356#comment:5>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
