[geos-devel] Re: [GEOS] #356: multilinestring buffer artifacts
Sandro Santilli strk at keybit.net
Mon Feb 28 04:06:29 EST 2011
On Sun, Feb 27, 2011 at 01:40:41PM -0800, Martin Davis wrote:
> The reason that precision reduction is invoked is probably because the
> generated buffer curve has some very close vertices - which tends to
> result in noding failures.  So this is operating according to current
> design (although it might be nice to find a way to reduce the number of
> very close vertices, e.g. by snapping).
Yeah. Only problem is that the final output in GEOS is just incorrect.
Rather than a polygon with an hole, it's a multipolygon of two
polygons (one within the other). No, the inner polygon doesn't match
the expected hole either (unfortunately).
> While investigating this issue, I came across another one, which is more
> severe.  If the output from this buffer operation is itself buffered by
> 1, the result is incorrect - it contains a hole which should not be
> present.  I"ve attached a test case. At the moment I don't have any
> ideas about how to fix this.
Your test succeeds in GEOS (no hole):
 Polygon[ZM] with 1 rings
    ring 0 has 74 points
Maybe is some recent refactoring fixing mine and breaking yours ?
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
