[geos-devel] Re: [GEOS] #380: Buffer(Geometry, 0) deletes part of the polygon
GEOS geos-trac at osgeo.org
Fri Jan 28 05:16:50 EST 2011
#380: Buffer(Geometry,0) deletes part of the polygon
 Reporter:  jaapdekker  |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  minor       |   Milestone:
Component:  Default     |     Version:  3.2.0
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 Can anyone check if JTS does a better job here ? If it does then it's a
 bug in GEOS, otherwise it isn't.
Ticket URL: <http://trac.osgeo.org/geos/ticket/380#comment:5>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
