[geos-devel] Re: [GEOS] #325: there is no destroy function for CoordinateSequence
GEOS geos-trac at osgeo.org
Tue Jul 5 07:32:19 EDT 2011
 Reporter:  aharon      |        Owner:  geos-devel@…
     Type:  task        |       Status:  closed
 Priority:  blocker     |    Milestone:
Component:  Default     |      Version:  svn-trunk
 Severity:  Unassigned  |   Resolution:  wontfix
 Keywords:              |
Changes (by strk):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 In JTS GeometryFactory is a class while CoordinateSequenceFactory is an
 interface.
 In JTS neither GeometryFactory nor CoordinateSequenceFactory have a
 destroy function.
 Anyway, if you feel like it'd be needed, you can provide a patch, but
 there's currently not much such functions would do beside simply using
 delete against the object, and unless you prevent directly using 'delete'
 I don't see much point in exposing an interface hiding that part.
Ticket URL: <http://trac.osgeo.org/geos/ticket/325#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
