[geos-devel] Re: [GEOS] #457: Port ConvexHull robustness fix from JTS-1.13
GEOS geos-trac at osgeo.org
Wed Jul 20 11:15:53 EDT 2011
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.1
Component:  Default     |     Version:  3.3.0
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 The test added in ConvexHullTest.xml doesn't trigger robustness issues in
 GEOS, I wonder if the modification in JTS were due to different
 CGAlgorithms results (orientation index...)
Ticket URL: <http://trac.osgeo.org/geos/ticket/457#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
