[geos-devel] compiling 3.3.0 on 64-bit RHEL 6
Sandro Santilli strk at keybit.net
Wed Jun 22 17:11:10 EDT 2011
On Wed, Jun 22, 2011 at 6:19 PM, John Cartwright
<John.C.Cartwright at noaa.gov> wrote:
> I'm getting an XMLTester error during "make check" after a successful
> compile (see below). Platform is 64-bit RHEL 6.1.  No options provided
> to configure.  Any ideas as to the problem?  Does this test failure
> suggest a severity that would prevent me from using the library?
> lt-XMLTester: GeometryComponentFilter.cpp:35: virtual void
> geos::geom::GeometryComponentFilter::filter_ro(const
> geos::geom::Geometry*): Assertion `0' failed.
Which compiler are you using ?
I have the impression I already read about such an issue.
Did you search on the trac instance ?
--strk;
Free GIS & Flash consultant/developer
http://strk.keybit.net/services.html
