[geos-devel] Re: [GEOS] #397: Valgrind reported errors with -O0
GEOS geos-trac at osgeo.org
Tue Mar 1 11:49:47 EST 2011
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
Comment(by mloskot):
 Sandro, this report is incomplete and does not say what version of GCC you
 are using, so the use of gcc296 workaround is confusing.
Ticket URL: <http://trac.osgeo.org/geos/ticket/397#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
