[geos-devel] Re: [GEOS] #397: Valgrind reported errors
GEOS geos-trac at osgeo.org
Wed Mar 2 05:11:30 EST 2011
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
Comment(by darkblueb):
 Linux xps-420 2.6.35-22-generic #35-Ubuntu SMP Sat Oct 16 20:45:36 UTC
 2010 x86_64 GNU/Linux
 dbb at xps-420:/home/shared/srcs_xps/strk_test$ gcc --version
 gcc (Ubuntu/Linaro 4.4.4-14ubuntu5) 4.4.5
 Copyright (C) 2010 Free Software Foundation, Inc.
 This is free software; see the source for copying conditions.  There is NO
 warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
 PURPOSE.
 dbb at xps-420:/home/shared/srcs_xps/strk_test$ valgrind --version
 valgrind-3.6.0.SVN-Debian
 dbb at xps-420:/home/shared/srcs_xps/strk_test$ libtool --mode=execute
 valgrind ../geos_trunk/tests/xmltester/XMLTester bug397.xml
 ==7815== Memcheck, a memory error detector
 ==7815== Copyright (C) 2002-2010, and GNU GPL'd, by Julian Seward et al.
 ==7815== Using Valgrind-3.6.0.SVN-Debian and LibVEX; rerun with -h for
 copyright info
 ==7815== Command: /home/shared/srcs_xps/geos_trunk/tests/xmltester/.libs
 /lt-XMLTester bug397.xml
 ==7815==
 Files: 1
 Tests: 1
 Failed: 0
 Succeeded: 1
 ==7815==
 ==7815== HEAP SUMMARY:
 ==7815==     in use at exit: 0 bytes in 0 blocks
 ==7815==   total heap usage: 25,343 allocs, 25,343 frees, 1,213,252 bytes
 allocated
 ==7815==
 ==7815== All heap blocks were freed -- no leaks are possible
 ==7815==
 ==7815== For counts of detected and suppressed errors, rerun with: -v
 ==7815== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 4 from 4)
Ticket URL: <http://trac.osgeo.org/geos/ticket/397#comment:7>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
