[geos-devel] Calling MinimumDiameter from C API
Sandro Santilli strk at keybit.net
Fri Mar 4 02:51:24 EST 2011
On Fri, Mar 04, 2011 at 02:13:41PM +0800, jiajianying wrote:
> On 2011年03月03日 20:29, Sandro Santilli wrote:
> >On Thu, Mar 03, 2011 at 04:28:09PM +0800, jiajianying wrote:
> >>How to extend C api? Edit the source file and submit to trunk? Is there
> >>any developer's guide?
> >Here's the guide:
> >1. Open geos_ts_c.cpp
> >2. Copy an existin function that "looks like" the one you're goin to make
> >3. Adapt to your case
> >4. Write a wrapper in geos_c.cpp (same thing: copy an existing one)
> >5. Write signature in geos_c.h.in
> >6. Send patch
> >Finally: use the mailing list for any further communications :)
> How long will the update be part of GEOS package(release/trunk)?
If you're in time, your change will be included in GEOS-3.3.0 to be
shipped most likely before summer.
> By the way, patches are sent with the trac system?
Yes.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
