[geos-devel] good to have visitor design pattern support
Debabrata Bardhan dbardhan at gmail.com
Mon Mar 21 08:48:38 EDT 2011
Thank for your input Sandro .  I have found some broken class diagram but i
cudnt find and such complete  class hierarchy diagram. Probably this task
should be go in todo list.
 On Mon, Mar 21, 2011 at 1:18 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Mon, Mar 21, 2011 at 12:44:30PM +0530, Debabrata Bardhan wrote:
> > Hi Sandro ,
> > how can i have any such pictorial diagram of complete GEOS class
> hierarchy
> > from which i can have clear view of the class hierarchy?
> GEOS is a port of JTS, and tries to track it as close as possible.
> Diagrams are in the doxygen-generated document (or should be).
> $ make -C doc apidoc && links doc/doxygen_docs/html/index.html
> Also search online for the JTS dox, as the design follows upstream.
> BTW, JTS itself uses the visitor pattern for some ops (*Filter classes).
> --strk;
>  ()   Free GIS & Flash consultant/developer
>  /\   http://strk.keybit.net/services.html
Thanks & Regards,
Debabrata Bardhan
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20110321/5fa14fd7/attachment.html
