[geos-devel] Re: [GEOS] #482: UnaryUnion of a non-simple linestring doesn't node it
GEOS geos-trac at osgeo.org
Mon Oct 3 03:20:08 EDT 2011
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.2
Component:  Default     |     Version:  3.3.1
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 NOTE: Martin added a test for this in TestUnaryUnion.xml and should add
 another in UnaryUnionTest.java. To be ported.
Ticket URL: <http://trac.osgeo.org/geos/ticket/482#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
