[geos-devel] Re: [GEOS] #299: geos::geom::CoordinateArraySequenceFactory unit test failing
GEOS geos-trac at osgeo.org
Tue Oct 4 17:38:12 EDT 2011
 Reporter:  pramsey         |        Owner:  geos-devel@…
     Type:  defect          |       Status:  new
 Priority:  major           |    Milestone:  GEOS Future
Component:  Unit Tests      |      Version:  svn-trunk
 Severity:  Unassigned      |   Resolution:
 Keywords:  mac,macosx,osx  |
Comment(by strk):
 The code in the typecastin example is not the same as ours. In our case
 CoordinateArraySequenceFactory::instance() should be returning a complete
 instance of a CoordinateArraySequence
Ticket URL: <http://trac.osgeo.org/geos/ticket/299#comment:27>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
