[geos-devel] [GEOS] #489: CMAKE_CXX_FLAGS overrides -std=gnu++0x
GEOS geos-trac at osgeo.org
Mon Oct 17 18:54:45 EDT 2011
 Reporter:  jyasskin    |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  minor       |   Milestone:  3.3.2
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
 I was trying to fix some problems in geos when building in C++0x mode, and
 I discovered that CMakeLists.txt puts -ansi after my custom build flags,
 overriding the -std setting. Here's a patch that fixes this.
Ticket URL: <http://trac.osgeo.org/geos/ticket/489>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
