[geos-devel] Problems with BufferOp when using BufferParameters
Markus Meyer
meyer at mesw.de
Wed Oct 26 06:14:59 EDT 2011
Hi everyone,
I'm using GEOS 3.3.0 on Microsoft Visual Studio 2008 (Windows 7) for
buffering lines using BufferOp.
I would like to use the BufferParameters class to control extended
parameters. However, it seems that I must be using the BufferOp class
the wrong way because my parameters are never accepted. To explain this,
I created a simple test program which offsets a rectangle.
When I do the buffering with the static function Buffer::bufferOp() the
resulting geometry looks OK:
// Working code
geos::geom::Polygon* pPolygon = dynamic_cast<geos::geom::Polygon*>(
geos::operation::buffer::BufferOp::bufferOp(
pLineString, fOffset, 16,
geos::operation::buffer::BufferParameters::CAP_ROUND));
When I do the buffering by using the BufferOp and BufferParameters class
directly, the resulted geometry looks very strange:
// Not working code
geos::operation::buffer::BufferParameters params(
16,
geos::operation::buffer::BufferParameters::CAP_ROUND);
geos::operation::buffer::BufferOp op(pLineString, params);
dynamic_cast<geos::geom::Polygon*>(op.getResultGeometry(fOffset));
From my understanding, the results of both code snipets should be the same.
Here you can find a plot of the results in both cases:
http://www.mesw.de/support/geos_rectangle_buffer_fail.png
Any help is greatly appreciated.
Best regards,
Markus
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20111026/a94bf316/geos_rectangle_buffer_fail-0001.png
